RCU Forums - View Single Post - soldering
Thread: soldering
Old 02-10-2004 | 03:34 PM
pettit's Avatar
pettit
My Feedback: (23)
Default RE: soldering
I use the new type solder that plumbers use for non-leadhousehold plumbing. It's made by Oatey and you can get a lifetime supply 1/2 pound roll at your local home improvement store for about 5 bucks.
I use the soldering flux used with Sta-Brite silver solder. They have an 8 ounce refill bottle, also about 5 bucks from your hobby dealer.
Be sure to clean off the flux after soldering. A paper towel moistened with alcohol works well, and then wipe on a little oil to keep it corrosion free.
4-40 rods and clevises need only a 100 watt gun to heat thoroughly. A torch will take the temper out of the clevises.
