RCU Forums - View Single Post - www.Learning 3D step by step
Old 02-10-2004 | 07:15 PM
  #149
mithrandir's Avatar
mithrandir
Default RE: RE: RE: RE: www.Learning 3D step by step
Hey Johnny.... I could see that happening!!! LOL... the biggest trick to 3D is coordinating closing your eyes with pushing the sticks in the corner!!! LOL
Italian-Flyer... maybe this will help?...
http://www.worldlingo.com/wl/translate
Another step forward for me in the case of Torque Rolls is this. Recognizing what control will fix the problem when the plane gets to where the fix will be a fix. "HUH?" you say... let me explain... lets say you are doin this *****in' TR. you notice it is not vertical due to a YAW upset. Do you fix this with rudder? Prob'ly not... WHY?... because of our old friend "TIME". If you see it is off in a yaw direction, in the time it takes for you to see it, recognize it, respond at the transmitter, respond at the servo, a half second has transpired... it aint a yaw upset anymore.. its a pitch upset... Kinda weird, but with time you get it.
I fly mode 1 also... we call rolling circles "Stirring Paint". The left hand ,elev and rudder, is basically moving in an elliptical pattern. Rolling circles require small elevator and lots of rudder. As the "Alphas" and "Betas" become larger, so do the amounts of elevator (Usually power is much reduced here to prevent climbing), and this becomes a rolling circular harrier. You must learn to "Keep the nose committed UP". (Towards the sky)
Who cares what mode though... Curtis Youngblood flies single stick!!!
hugs and kisses!!!
read this one too if you live in southern california...
http://www.radiocontrolzone.com/foru...hreadid=157719
Hey Johnny.... Potrei vedere quello accadere!!! LOL... il trucco più grande a 3D sta coordinando chiudendo i vostri occhi
con la spinta dei bastoni nel angolo!!! LOL
Italiano-Aletta di filatoio... forse questo aiuterÃ*?...
http://WWW.worldlingo.com/wl/translate
Volo il modo 1 inoltre... denominiamo i cerchi di rolling "che mescolano la vernice". La mano sinistra,elev e timone, sta muovendosi basicamente in un modello ellittico. I cerchi di rolling richiedono il piccoli elevatore e lotti del
timone. Come "l'alfa" e "Betas" diventi più grande, così faccia gli importi dell'elevatore (l'alimentazione molto è
ridotta solitamente qui evitare l'ascensione), e questo si transforma in in un harrier della circonvallazione di
rolling.
hugs e baci!!!
