pacific models gee bee-Y arf
Sorry guys i was on vacation just got back monday 07/08/02 I've just started on the G.B.Y. I used the CA hinges I'm not to king on them but they are big enough used plenty of CA on them .Thier not going anywhear. I used Greatplanes large control horns.and the spring style tail wheel.On the ruder i used the threded rod with the two lock nuts on each side. They said to only use one servo but since we have to locations cut out already i'm going to use two besides from what i hear you can use a little tail wieght.On the wing i'm useing two S9202 on elevator two S9202,and on ruder two S9204 just cause i have them. Now i'm going to epoxy the stab & fin in place .Then i'm going to glue the wing together. Like i said before to much wing to leave in halfs. I just can't trust that system .I'll glue the tube ,peg,& wing roots together. So it may be a little harder to transport but i'll feal a lot better doing a loop. I'll keep you fellows up dated on my progress Andrew
