Saito 170 thoughts
Pettit,
Thanks for the info on the 170 cooling issue. That's one I issue guess I didn't take into consideration too well. This still hasn't distracted me from this plane even if I have to use another engine. It's just that the 170 seems so fitting for this bird. I imagine even making a larger exit hole in the bottom of the cowl wouldn't cure the problem since I'm dealing with a radial.
Dan
