RE: Grade of C-
1. I have been doing the cut and paste dance, but thanks for the tip anyway. It works most of the time, but I have found that if I close the spelling check popup before I paste, I sometimes loose the entire reply as I paste in a null over my existing pre-checked text. I've just learned to keep the popup open until I'm done pasting.
2. The Forum not found seems to happen when I'm in a thread and click on the !QUOT!forum home>>!QUOT! at the upper left of the screen. I can't seem to nail it down exactly, but it seems more prone to happen if I am in the plane forum and have not yet viewed anything in the general forum. It typically happens to me once per RCU session. I've had this problem on three separate computers so I'm pretty sure it is not at my end. Anymore I avoid the problem by working my way back out to the form home one level at a time. This works, but takes longer.
3. On the longer threads, it would still be nice if there was some way to view the entire thread while composing a reply. What I do now is spawn another browser to view the thread. The old system showed the entire thread. I'd even settle for pictures stripped, or the reply form spawned to a popup or another browser... that would be fine too.
I really hate to even mention these things as I'm sure a large portion of your job is thankless, and I do appreciate all the work you put into the site, but these issues make my RCU time less enjoyable so I'm just suggesting you look closer at these issues. Cheers.
Edit: Doh.... You can forget #2, I figured out what was happening. My bad. I apologize.
