RCU Forums - View Single Post - T- Pins better Idea?
Old 02-11-2004 | 07:14 AM
CafeenMan
Default RE: T- Pins better Idea?
ORIGINAL: ED STEFAN
ORIGINAL: CafeenMan
How about gluing the rubber to the disk? Then you should hook up a power supply and you can have a Padded Power Pin!
ROLMAO -- I'm on it!!
I did try the TZ with a patch last night. IT WORKS GREAT! I used a small hole punch to produce the rubber patches, but I think a larger hole punch might be better.
I plan on making about a 100, or so. I figure 2 - 3 beers ought to do it. [sm=tongue.gif]
I think this should be its own Poll thread. "Should people drink while bending T-Pins?"
If you put a piece of paper on each side of the rubber, it will cut more cleanly. That's how I cut circles out of Monokote too. Works very well with the monokote - not sure how well it will work with the rubber.
