RE: Using glue properly.
I agree with CafeenMan, use any of the alphatic resin glues. While there are many good ones, my favorite is Titebond II as it is quite water resistant as well. Just make close fitting joints and it always helps to use enough clamps or jigs to keep the joints immobile for at least 20 minutes, preferably longer. If and when you use any epoxy, shy away from the fast setup times, use at least 30 minute or slower. Even then all epoxys (including the 5 minute type) do not reach full strength for about 24 hours or more.
