ORIGINAL: Turbobruce
The plane will fall pretty hard when inverted but I'm also at the point that when I land I balloon once I chop the throttle. I'm a little concerned that if I start adding weight it will really be a pain to land due to stall or excessive ballooning. You guys really dont think the thrust is an issue here????. I will go back to the stock thrust settings and start adding weight in the tail. Wish me luck.
If you balloon when you chop the throttle then that's definitely a thrust issue, in this case too much down.
Take the "down" out and put some "up" and see if this improves things.
Stratos.-
