RCU Forums - View Single Post - Brake problem
Old 02-12-2004 | 05:45 PM
skydalimit's Avatar
skydalimit
Default RE: Brake problem
use a balloon on your reciever, another thing is you could simply have a to lean needle setting on the lowend, i would righen that up a little, also, shut the carb as far as it will go in, if the idle isnt the problem then it has to do with the gears, if the gears are the problem then just take it apart and replace them accordingly
