I have the idle right were I want it. Kinda running high. But I'll figure this who thing out.
um he already found the problem.
I havent figured it out yet.
use a balloon on your reciever, another thing is you could simply have a to lean needle setting on the lowend, i would righen that up a little, also, shut the carb as far as it will go in, if the idle isnt the problem then it has to do with the gears, if the gears are the problem then just take it apart and replace them accordingly
How could it be the gears?
