RE: RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box!
I just bought a Stanley box and I have a few questions. I dont have a power panel, so is there anyway i can make it easier to get to the 12v (its in the bottom with the fuel)? I would have to take the box apart and keep switching between the fuel pump and the starter. I was think of cutting a hole right in front of the battery but I would rather not. Did anybody set up there box without using a panel?
Also, im confused about how to set up the fuel lines, on my cap there is one piece of fuel tubing leading to the pump, and then theres another one that you use to fill the tank, it gets plugged in and out of the cap. Now i guess i could drill two holes and have a fuel dot in one of them to plug the fuel line into but what do i do with the original plug in the cap? Should i put some silicone in it to seal it up or what?
