RCU Forums - View Single Post - Stingray Construction
Old 02-12-2004 | 11:25 PM
  #320
RC_Pilot2k's Avatar
RC_Pilot2k
My Feedback: (26)
Default RE: The guts of the stingray
That's great! Thanks for all the info...I forgot to ask one more thing...the retract valve diagram. I've only used Spring Air retracts in the past, so this 5-way valve has me stumped. Three nipples on the left, two on the right, what goes where? AND, do I just "T" the mains together for push/pull to have only TWO lines going from the valve to the back? Maybe Yellow can add a simple diagram with the kit in the future (if buyer purchases their retract system with the jet of course, like we did). Thanks again for the above info. I haven't made it to balancing the plane yet, but it sounds like my idea of putting all the batteries in the nose is going to be too nose-heavy.
I also have a radio question: Is PCM required for turbine jets? I'll be using a JR 783 FM with a simple 6-channel receiver, since I won't be using flaps, smoke, or brakes (yet). I've talked to a few of the scale jet guys and they all say you have to use a JR 10X or the like. Is it just because of the extra channels? I've flown a diamond dust for a while with a 4-channel non-computer radio at speeds well over 150mph and it's range is fine...never had a glitch. I've also flown ducted fans (yech) with a basic FM radio with no problems. I don't see the big deal of which radio system is used on a Turbine, other than the fact that you need extra channels, because in regards to electronics, the turbine engine has significantly less vibration than a glow engine.
