RCU Forums - View Single Post - cermark pitts
Thread: cermark pitts
Old 06-03-2002 | 06:57 PM
rsallen13's Avatar
rsallen13
Default cermark pitts
I have this plane and really enjoy flying it. It comes with all the nessary hardware but you will probably change some of it.
A couple of things.
One the center cabane is wood and you will need to do alittle fiberglassing arounds the tops if nothing else to make you feel comfortable that it will hold up. I changed out the rods connecting the ailerons again not because they didn't work. I just felt more comfortabel that it wouldn't fail.
I have a Webra 1.20 in mine and it will do anything I ask. You will need a perry/versane pump with the webra as the tank will be alittle below the carb if you do not mount it inverted. mine is at 90 deg.
Any motor mounted inverted would not have this problem.
If you wish to go gas beef up the firewall alittle and even though it says it will fly with a g-23 go a little larger. a 2.0 cuin gas on ignition would be perfect.
Overall
