RE: TRIM OR MOUNT ADJUSTMENT REQUIRED
Nose heavy plane will do this also. Try moving the CG back a bit to see if it straightens out. Another way to tell if it's a CG problem is wether it takes a lot of down elevator when flying inverted. Should take very little.
