antenna reciever wire
What is said is correct. Copper is a better conductor than aluminum, but either will work. The antenna used is considered a monopole antenna and can be “tuned” to the correct frequency by sizing it correctly at a quarter-wavelength (one-fourth the length of one cycle of the electromagnetic radio wave). Since our radios operate with a carrier frequency about 72-73MHz (depending on the channel) the characteristic length of the antenna will vary from 37 to 39 inches. Anything outside of this range will cause degradation in the received signal.
Rock Chalk Jayhawk!
AMA 770311
