RCU Forums - View Single Post - Eclipse7 and dual elevator servos?
Old 02-13-2004 | 08:21 PM
mglavin
My Feedback: (31)
Default RE: Eclipse7 and dual elevator servos?
Mike is away for a bit. I'll try and help.
The Eclipse has several mixes available to manually program as you desire. BUT there are default mixes and these may serve your needs. Activate a mix, adjust the variables and use two servos with their respective connectors into the listed RX ports, and the servos will work as one. This method is preferred over a wye. You are able to center and adjust the surface end-points as needed.
As mentioned below, the single problem I note for your application is the mix MUST be activated by a switch, this switch must be left in the ON position...
