RCU Forums - View Single Post - How To: Calibrate your Accu-Cycle
Old 02-14-2004 | 01:25 AM
Juice
Default RE: How To: Calibrate you Accu-Cycle
7) Do exactly the same thing to calibrate the Rx discharge rate. I'm too lazy to take the battery out of the fuse, so I brought the whole fuse over. Remove the switch and connect the battery directly to the charger. Change the "RX CELL SELECTOR" to 1 cell (don't know why), hold the multi-meter in series again, then start discharging. (Picture #1)
8) Adjust the Rx pot until you get 250 mA. (Picture #2)
9) That's it! Screw the top back on. Notice I used 18 mAh and 20 mAh to adjust the Rx and Tx discharge rates, respectively. Top off your batteries before you start cycling again. This time you'll be more confident about the mAh readings at the end of the discharge. (Picture #3)
I hope this helps...
Juice
ID:	100722   Click image for larger version
ID:	100723   Click image for larger version
