RE: Perry Pump - VP-20 Oscillating pump
had one with 180 saito mounted on a glass mount...mount allows to much vibration causing the pump to pump erratically! (oscillation pump's pressure is proportional to the shake intensity)
if you go this rout, better use an aluminum mount ...but i would go with a cline type system.
I have the perry pump sitting on the shelf!
