RCU Forums - View Single Post - Supporting carbon push rod
Old 02-14-2004 | 08:58 PM
rgreen24's Avatar
rgreen24
Default RE: Supporting carbon push rod
Depending on the length of the rod you may want to use support. The reason why the rods break is the vibration gets the rod to move to a certain harmonic pitch and then snap! What I did and learned this from many pattern flyers is that I have a piece of foam about midway between my bellcrank and where the servo is mounted. the foam acts as a dampener for the push rod, and will not allow it to get the harmonic pitch that would cause failure. I use silicone to attach it to the inside of the fuse. (of course this is just my 2 cents)
