RE: Looking for a predator type of spad flying wing.
To make the SSC design fly well you need alot of wing area. 650" to 750" and at 2lbs 8oz. Its in the wing loading. So you are talking about a 64" wing with 11.5" cord. Once you start talking about that much coro your weight goes way up. I think a there are plans on line at spadtothebone.org . Look for the Sickle. Weight would be the biggest problem .
Foam wing are the lightest and strongest. If you have built all the SSC .15 I am sure you would have no problem cutting your own wings. I started out using a car battery and a 2x2 36" piece of wood for the bow with some music wire. Some learning curve but worth it.
Ron
