RE: Moki 2.10 running lean when pointed up
Columbo...
There ya go. You're going in the right direction.
If you need a pump...so be it. (I am just averse to added complexity if it's possible to avoid it)
It can be VERY revealing to hold your model vertical and run through the rpm range slowly. A motor
that is otherswise a real sweetheart can suddenly have all sorts of problems.
The hover attitude is a worst case scenario for the motor and it's fuel system.
Good Luck with it!
