RE: What engine to get?
The only thing you have to worry about is space. Once you put a larger clutch bell on, the added size of the gear pushes the engine farther away from the spur gear. As long as the slots for your engine mount are long enough, you shouldn't have a problem. 18T should fit in most buggies. I'm told it fits in mine.
RobH
