RE: Reduced propeller diameter
Hi Marcos,
It should perform more or less the same, if the tips are rounded as the original 12*6. Nevertheless I must said that the angle at which the prop ends at the tips would be not flat at all, given a little bit more extra torque.
Como esta todo en Puerto la Cruz?, que envidia, puedes volar todo el tiempo!!.Por aqui no puedo todavia. Estamos bajo cero. Un cordial saludo de un otro Venezolano.
