RCU Forums - View Single Post - enough power
Thread: enough power
Old 02-16-2004 | 07:30 PM
BMatthews's Avatar
BMatthews
Default RE: enough power
The one site I found gives a weight of 18 to 20 oz but does not say the wing area.
If you can keep it under the 20 oz they mention and if there's 270 sq inches or more of wing area it'll fly fine and be quite capable of moderate aerobatics. This weight and size is very typical of the 1/2A Texaco models. Those class models are held back by using an oversized prop to enhance the duration of the engine run off the limited fuel they are allowed to carry. But if you put a 6x3 on the Cox engine they use they can really get up and dance. No 3D stuff you understand but I think you'll be surprised at how capable the Rascal can be with a strong 049 like the AME IF the demon enemy WEIGHT can be kept under control. If you can keep it to 16 oz then it'll be giggle city every flight.
