RE: Can anyone help?
well now i am down to just battling this "new" problem. I have got the thing pretty stable, probably as good as it is going to get. It is this damn glitching that is pissing me off now. Just today because of the power glitch it crashed. I was a couple of feet off the ground, power was lost for a second and slam into the ground.
Here is the setup I am using. Astro brushless 020 with CC controller 45 amp i think it said it came with a 35a but the instruction manual says 45 amp controller. I am using a Hitec receiver and Futaba radio, 8 matched Sanyo 3300 cells.
These are the problems i am having.
1. loss of power for a split second, say every 15 seconds, but doesn't do it all the time. 2 and everyonce in a while it seems as if the motor puts on the "brake" and sounds like it is going to strip the main spur gear which it slowly is. Yes, the brake is disabled!
As chpoppa123 suggested about the deans antanna, yes it is fine like he said it should be and connections seem fine. I have no idea what the problem could be!
Anyone else using the Asto set up have any of these problems?
