RE: Seagull Models Zero ARF - Online Build
1 & 2) My Zero has its c of g set at 85mm measured back from the centre leading edge root rib. The model has around 7ozs of lead in the nose even with a .53 2-stroke engine fitted!
3) Fitting pieces of fuel tube over the clevises will help keep everthing safe, even with the supplied clevises!
