RE: extra300s
Looks nice. I had a Giles 202 that was very similar in size and weight, put a MVVS .91 2 stroke up front with a standard quiet silencer...found it under powered to be honest, all depends on how you want to fly the plane obviously but the vertical performance was shocking, was flying at almost full throttle all the time, and take-off's were marginal getting off the grass at my field. If you are going with the 90 size engine I would recommend adding a good pipe.
