RE: Edge Pics?
Do you know the registration or "N" number of the airplane? I can't zoom in close enough to read it. If you have a higher resolution image, you might be able to tell what it is. If you can get that bit of critical information, you can go to the FAA aircraft registration database and get the owner's name & address. I would then call/write the registered owner. I'm sure he/she would be excited to know that someone is building a model of their airplane. If they have a digital camera, they might be willing to take all the detailed photographs you could ever want!
Here is the link to the FAA's database search engine:
[link]http://162.58.35.241/acdatabase/acmain.htm[link\]
If you don't know the "N" number, you might want to check with Bob Banka's Aircraft Research. He has 7 Edge 540s listed in his current catalog, although none of them seem to match the color description of this aircraft. I'm sure he adds Photo Paks all the time. If this airplane is new (which I suspect it is), it might not have made his latest catalog. Best of luck!
[link]www.bobsairdoc.com[link\]
