RCU Forums - View Single Post - Scratch Built Ignition???
Old 02-17-2004 | 03:16 PM
  #144
ramrod25
Default RE: RE: Scratch Built Ignition???
Summarizing, it appears that the CH ignition system needs the ignition module, coil with the option to attach the plug wire, hall sensor, magnet, enclosure, wire/plug to attach to a battery, and a cable to ground to the engine case. Total cost should be in the $80-85 range.
The TIM-6 system with the “PE” coil plus shipping is in the $50 range, and will need some wiring and a plug to attach to a battery.
I would assume both systems would be happy with about a 1200 mah 6 volt battery.
I would also guess that with both systems one would want to run a resister plug and a shielded plug wire.
Does that pretty much summarize both systems?
Ramrod25
