I have already solved the sagging tail. I made it a tail dragger. I was refering to the mains for a taildragger config. I moved the main gear blocks in front of the spar, and then sheeted them in. I can get to them if really needed, hope I dont ever have to. I plan on using a pull-pull spring set-up on the tail wheel. I just need to decide on a motor. Then I can start the fuse. I wish the fuse was a little less box'y. Maybe I should build a Chipmunk next, this Tiger was not really my choice but I'm making the best of it. I really enjoy the building and this kit is going together tooooo fast.
