RE: BIG problems with Eclipse7's in AUSTRALIA
Sounds like you have range problem, more likely than not based on your comments the TX maybe the problem. Why not return it to Hitec Service for evaluation. Be sure and include the TX modules in use, I would also send in the RX's if possible. Better safe than sorry.
You mention "almost unflyable with a 100' range". Antenna down range check or?
