RE: retiming ? on GWS EPS-350C-DX
I retimed the motor in my 350c. Apparently the 350 does need retiming, as it is set at 0 degrees so it will work ok in either dierection. I rotated the back plate just 1/8" or less. I can't say for sure that it helped or hurt. I would like to set up a test of amp draw vs thrust, and try several different settings and find out for sure.
