RE: Ground loop
it may need some right thrust some planes do some dont you might try putting washers under the left side of the motor mount if you can. also maybe just try accelerating slower if possible, just feed the power in smoothly what you have there is a tail dragger and they can sometimes be a little tricky to get off the ground. so if the thrust angle is off try washers but it may just need to be finessed off the ground
