RE: HPI MT2 problems
any more help out there?
i have another question about the carb and linkage set up - should the piece on top of the servo that the linkage for the brake and throttle alway move togethor?
i ask this because if you set the idle at neutral to have a 1 mm opening in the carb it will always close when you brake if the servo moves both arms back.
this is what is happening to mine. it seems that when you brake the throttle linkage should stay at neutral instead of moving back which causes the carb to close and die.
thanks
