RCU Forums - View Single Post - HPI MT2 problems
Old 02-18-2004 | 12:28 PM
ragin_cajuns
Default RE: HPI MT2 problems
ORIGINAL: nitrofreak74
i had the same thing with my mt 1, set the carb first to 1mm then set the servo linkage, it may take a little time to get it right.
set it to 1mm while it is in neutral right? the problem then occurs when you hit the brake it pulls the carb closed.
