RE: What are gear Drives (gear Boxes) for?
Well yes a bigger prop gives you more thrust but at a cost of shortening the motor run time. Bigger prop also increases the amps a lot! Easy way to kill a motor. Also depends on the amt. of lift the wing can produce. The wing after all does the lifting the prop just moves the acft. forward.
