RE: HPI MT2 problems
can anyone answer this?
what keeps the carb open when you brake? my servo pulls the throttle linkage back when you brake which closes the card killing the engine. if you open the carb more so it remains open when you brake then it is too open (idles too fast) when you let go of the brake (neutral)
should the throttle linkage be pulled back when you brake? i don't see any way around it.
