RE: Using the OS 91 in the TF Spitfire?
The OS .91 four stroke would work fine for the TF Spit, provided that you build the Spit light. This engine is not too big, powerful, or heavy for that plane. In fact, chances are you will need to add nose weight. This engine will also work fine for the F4U. I have the pumped .91 Surpass II, and it's a sweet running engine with plenty of power.
