Make sure that you put as much distance as you can between the two antennaes
ORIGINAL: mitoor/c
i have purchases a Futaba 9-C pcm radio, and want to know if i can use hitec 7 channel receivers with the transmitter. I have a new plane i am planning to use 2 receivers in, and the hitec receivers are a lot cheaper. The receivers would not be pcm Thanks..
