RCU Forums - View Single Post - building first airplane
Old 02-19-2004 | 10:42 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: building first airplane
I would use 30-min epoxy, and glue it in place. Then have a shim ready to epoxy under the stab. Don't worry about completely sealing the gap, if you get more then 50%, that should be good enough.
Just make sure that the stab is level with the wing, and square to the fuse!
