RCU Forums - View Single Post - Supporting carbon push rod
Old 02-19-2004 | 11:16 AM
tommy s
My Feedback: (55)
Default RE: Supporting carbon push rod - and vibration
True Temper Dynamic Gold Lite Iron Shafts - 110 grams / with sensicore 114 grams
True Temper Dynalite Gold Iron shafts - 118 grams / with sensicore 122 grams - etc,etc,etc.
Out of True Temper Catalog.
My brother is on Ping's and Callaways and several others staffs and has tried every
imaginal shaft combination you can think of. I can tell you without any doubt the foam
inside the shaft does nothing by itself. Some companies use a lighter weight shaft if it
is to be used with Sensicore as adding Sensicore to a shaft definitely adds weight.
If I were to use foam to dampen a carbon fiber pushrod I would put it around the outside
of the rod as discussed earlier in this thread.
tommy s
