RE: retiming ? on GWS EPS-350C-DX
[8D]
LOADING--did it real close. From what I have heard, the 350's should be checked because they are 0 timed....They run the same either way. You want to ADVANCE the timing so it revs higher, and pulls slightly more power, in the right direction for the prop. The 300's and 370's were timed for direct drive props, not gear drive, where the motor has to turn backwards from direct drive. Some have actualy has less draw and much more power retimed. The motors were that "retarded".......
[8D][8D]
PHIL I.
P.S. I am a firm believer in water breakin....Do a search on it....
