RCU Forums - View Single Post - H9 Cap CG Question
Old 06-08-2002 | 12:23 AM
Brokenprop
Default H9 Cap CG Question
I'm not sure how to put a picture on here. I tried to drag and drop one here last night and it just opens another brouser screen. I put another set of servo bearers across the fuse positioned closer to the top of the fuse. You can then slide the servo anywhere from left to right and the arm is higher in the fuse than the pull pull cables by about 1/2". Looking down into the inverted fuse the way you work on it, the servo and arm are below the cables. Then I positioned the hole on the arm I intended to use right in the center of the fuse and anchored the servo there.
I'll try to email you a picture, I know how to do that.
