RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 02-20-2004 | 01:45 AM
  #807
Tomi
Default RE: U-Can-Do 3d 46?
Thanks Red,
I can't seem to find that size prop. What brand did you use and what is the prop made of? I'm thinking about just using the 12x6 wood prop that is recommended. I'm new to this so I'll give them props a try and figure it out from there.
Last question. How slow can you get this plane going for landings?? Do you give it a little more throttle over idle and just float in or just idle it in? Well it depends on how the winds are blowing too so, I just need a estimate of how much throttle you guys are using to float it in. I'm used to flying in fast with the carbon built gliders and when you hit them rotors man, the glider rocks around. I bet this UCD46 is gonna be so easy to land!!
p.s. All these good things I've read on this plane makes me feel good that I ordered it.
-Tomi
