RCU Forums - View Single Post - removing CA thin??? probably not.
Old 02-20-2004 | 11:51 AM
turbine2
Default removing CA thin??? probably not.
Hello there, here's the deal, I am in the process of building my first kit (spirit 100) and I made a stupid mistake; I glued the doubler onto the fuselage on the same side as the other one. Not sure if that makes sense, but the point is that I need to get the doubler off of the fuse side. I glued it using thin CA all around. I am just out of luck? Or is there a trick to separating these two sheets? I have started to separate, but it is tedious and I feel like at any second I could end up shattering the wood. Any ideas???
