RE: removing CA thin??? probably not.
CA Debonder wroks fine, but depending on the amount of CA you used it ight be difficult to remove it and that is a big part with lots of contact area.
But you will need lots of debonder.
You can use Acetone if you don't have the debonder, also some nail polish removers are acetone based.
worst case you might need to sand it down and cut another one.
hope others might come with a better idea.
Good luck,
