RCU Forums - View Single Post - Electrical wing coding
Old 02-20-2004 | 08:37 PM
phread59
Default RE: Electrical wing coding
In electronics black and brown are almost universally grounds. I would be suspect of any wire having a tracer (the stripe). Usually any wire with a tracer is a hot or signal wire. I would suggest you check all wiring with a meter before hooking up unknowns. My field chargers and so on I bought premade wires that just plugged in. I hope this helps in some way.
Mark Shuman
