Use acetone starting on one end and a razor blade as MinnFlyer said. Then as you work the acetone around the joint, keep moving the razor blade to help the part lift off.
Don't feel bad. You won't be the last guy to make two of the same fuselage side. It's a common mistake - even among experienced builders. Some of us even build two left wings.
- Paul
