RCU Forums - View Single Post - Kangke Cap232ARF
Old 02-22-2004 | 01:34 AM
majortom-RCU
My Feedback: (40)
Default RE: Kangeke Cap232
What CG are you measuring from? If it's less than 30% of MAC, you can try balancing back that far as a fall-back point. Manual recommendations are typically conservative. Do you have room to re-mount the engine further out from the firewall? I would try to hang the cowl out as far as possible, add an engine box or stand-offs or whatever to minimize the amount of lead. If you do the engine box, then you could probably move the throttle servo right up behind the engine, probably also put the battery further forward. Throw in a redundant battery, might as well get something useful from the added weight. Also look for anything you can do to take weight out of the tail. If you have sheet balsa tailfeathers, I'd replace them with framed up stick balsa. A pound of lead is worth a lot of rebuilding in my book. If you move the engine forward, do you have room to move the landing gear forward as well? Even a half inch further forward will save some lead in the nose. Do you have a bigger engine you can put in? I'm getting ready to put a Kangke Extra ARF together (more or less same size as your CAP), and I'm thinking SuperTigre 2300 for power. Bigger engine with less lead will fly lots better than smaller engine more lead. Wanna buy my old SuperTigre 3000? It runs good, pulls like a horse, weighs 3 pounds! For less than a hundred bucks, your problem would be solved!
