RE: BPL Moving Forward
I should also add that 72 MHz propagation is almost exclusively line-of-sight, so any BPL interference will be limited to what is generated locally.
Spread spectrum may help but is not a cure all. cetain minimum signal level is still required, nomatter high wide the spreading and how elaborate the coding.
